a/c water pump
i took the boat out for the first cruise of the year. all systems go,, except the new a/c. over the winter I installed a new a/c system, the boat never had one. the a/c will come on and pump cold air until it gets hot and then it shuts down with a E1 error code. the a/c is a webasto with a march pump. I have power to the circuit board and a green com light. it acts as if it will not command the pump to come on. since I have never owned a boat with a/c should the pump come on when the compressor does or does it command the pump only when it needs it. I have water to the strainer before the pump. could I have plumbed the strainer or pump backwards and misdiagnosed the power supply issue?
ok guys I figured it out with your help!! it was not primed. I have learned that the march pump is 110v. I also learned that the a/c will not command the pump to come on until the compressor comes on. so my problem was the compressor would come on send a command for water and would not get any so the over heat protection would shut it all down. the solution today was to hook the flush adapter to the thru hull with the garden hose and hot wire the pump until it circulated thru the a/c w/o the a/c on.
now that I have it primed will it hold this prime while sitting on the trailer and or trailering to the lake?
