Outdrive trim works at idle but not when on plane
EDIT: This problem was caused by faulty adjustment of the trim position sender, not a problem with the hydraulics. See details here:
https://rinkerboats.vanillacommunities.com/discussion/11835/solved-after-seven-years-outdrive-trim-works-at-idle-but-not-when-on-plane
I suspect a weak trim pump -- looking for suggestions.
One of my Bravo III outdrives refuses to trim up at cruising speeds. At idle, it works fine up and down, so I know the switches are all working. But when I get up to cruising speed and try to trim the drive up, it won't move. My theory is that the hydraulic trim system has enough power to raise the drive with no load on it, but not enough to do it at cruising speed.
Anybody else have this problem? Should I replace the pump, or try the 18545A1 rebuild kit? Any chance it's the rams instead of the pump?
The pump has no visible damage, no history of fluid loss, and no strange noises when I run it at idle. The rams look fine and are not leaking fluid.
Thanks.
Thanks.
Post edited by LaRea on
2014 Rinker 260EC
2014 Rinker 260EC
I suppose it could be a weak electrical connection -- unlikely, but easy to check.
After that, I'll swap the pump from stbd to port. If the problem moves with the pump, it means the pump is bad. If the problem stays on the stbd side, it means I need to haul the boat and check the trim cylinders.
At speed, the trim cylinders see two opposing forces: the water is pushing the drives up, but the bigger force is the propeller thrust pushing the drives down. That's why the trim cylinders have to work harder on plane than at idle -- right?
What's odd is that everything works perfectly at idle, but not under load. How could it be a solenoid/relay problem? I would think the solenoids either work or don't, and it's independent of the mechanical load.
(My previous comment about being an instant expert on trim pumps was made tongue-in-cheek ... I obviously have much to learn.)
A couple things I noticed:
1) When I rebuilt the stbd pump, the fluid that I drained from the reservoir was a thick, baby-puke green instead of the normal clear-brown. Maybe the PO accidentally topped off with gear lube instead of trim fluid, although it doesn't really smell like gear lube. (The fluid in the port pump looks fine.)
2) Now that I've swapped pumps, the stbd drive actually will move up *slightly* when on plane, but not far enough. Below 1800 RPM, it has full range of motion. For anything above 1800, it will move just enough that I can tell it moved, but not enough to properly trim the boat.
For now, I'll continue using it and just trim up as much as I can.
@LaRea. I am having the same issue now that you described. What was your final fix?
juat replace the electric pump motor
4 screws
tank
pump
electric motor that either Spins cw or ccw
most of the time it's the motor not pump
That would also explain why the problem stays with that outdrive.
So, I have now replaced the trim position sender/limit switch, cylinders pump and motor. By process of elimination, it has to be a bad solenoid.
Anybody need a slightly used but known good trim pump?
EDIT: It was the position sender, not the hydraulics. Details here:
