audio question
i have a 2004 232 open bow . it has a sony 52w x 4 marine radio , 6 polk audio 6 in speakers and a xplod 220 watt amp.only the front 2 speakers are hooked up to the amp . when I turn it up loud the radio turns off and will keep turning off and back on until I turn it down . ive been told I need a bigger amp or a better radio. im not sure what direction I need to go in . thanks for any help
If it is a 220W PEAK amp though, that is not big, and likely it is overheating. If it is 220W RMS, that is more reasonable and should be pretty loud.
Low resistance can also be caused by short circuiting the speaker wire. I don't think you have a direct + to - short because your amp wouldn't work at all then, but you may have one tiny + wire touching something semi-insulating in the boat.
Check out this link for more info:
http://denon.custhelp.com/app/answers/detail/a_id/58/~/4-ohm-speakers-with-a/v-receivers-or-power-amps
How are you shutting off the other 4 speakers? So you are using only 2 speakers and cranking the amp up full. I think MarkB is correct about amps and resistance in your system. The wattage maybe exceeding the limitations of your 2 speakers.
Art
