Still cleaning out raw water cooling system from broken impeller
rasbury
Member Posts: 8,740 ✭✭✭✭✭
I started a new discussion because the previous thread was question I marked answered so figured I needed to start over?
I opened up the starboard side removing the end cap. I now see the tubes are set into another "end plate" 2" or so back so now I see why I don't have coolant all over so I'm now good with that. What I still am not understanding is how the water gets into the tubes....the inlet to the exchanger is not routed to that space between the end cap and the other "end plate" where the tubes start but a little behind that.....there is a hose coming out of that space but goes to the starboard side riser I guess it is...there was nothing of any sign of impeller pcs. in that space but I don't see how any would get there in the first place! I'm thinking I should have pulled off the hose where it goes into the exchanger as that is where it would collect stuff? I have the manual but I'm just not getting it. I'll go look again at the manual....sorry to be so thick on this!
The only other way to truly avoid boat maintenance is to do what I did....... but don't do it.
