Gauges ( most) and trim tabs stopped working after battery change out
edgeofred
Member Posts: 7 ✭
Had a reputable mech change out both of my batteries. Prior to this, I am 100% sure that temp, tach, trim and oil pressure gauges were working great, also trim tab contol. Now only the fuel and voltage gauges still work. Mech has yet to find reason but claims battery change out had nothing to to with it just" a boat thing". Mech mentioned the Mercruiser "smart control?" box could be the issue. Three years (2011 Rinker, 276BR) with no gauge or trim tab issue and the very 1st timeter used after battery install this issue arises. Any thoughts or advice. Thank you!!
Guess what? All of those items except the two you mentioned are pcm controlled except the trim control..
A battery change could cause a pcm issue, but doubtful... They're pretty tough...
I gotta agree with him, but not leaving him blameless: look carefully around the area of the batteries for a stray wire (or bundle of wires) with a battery post loop on them. I wager he simply missed reconnecting them.
