F.V. 250 2004 engine location
Hello to you, I just bought a 2004 Festiva V 250 with the mercruiser 350 mag horizon (closed cool), with 300 hours on it. Very nice boat and I like it a lot but I am concerned about the lay out of the rear bulkhead, directly in front of the engine. Here is my question, how is anybody supposed to be able to change a raw water pump (under the alternator) fresh water pump, serpentine belt or pulleys on that engine,as the front of the engine is under the deck with the hatch open and a mere six inches from the bulkhead? do I have to cut an opening through the bulkhead wall to get to the front of the engine or pull the engine right out? Any comments or solution would be greatly appreciated.
****, I built a 2x6 brace and used a tackle powered by my trucks winch to **** mine out.... It took me likely ten hours from getting home from the lumber yard to having it constructed and the motor hanging from the manifold eye bolts... There isn't much to it..
H. E. L. L. .... Not really a bad word, fellas... But, okay... I can get some thinking otherwise..
S. N. A. T. C. H. ... To quickly grab... Okay, so it has a possible other meaning, but I've never heard it used outside some cheap pornography or outside the barracks...
****, I snatched that engine out in ten hours from starting with a pile of lumber to it dangling from a tackle block and winch cable... was that really that bad?
However if you are doing all the jobs you list, as another poster suggested, pulling the motor is routine, although it requires the boat to be out of the water and it'll cost you in labor. An empty engine bay allows other work too, cleaning the bilge, checking the bilge pump and switch, etc.
Andy
Yes, pump and belt replacement is a pain, but not a reason for me to sell a boat I love, especially in light of the major problem I just dealt with. So working on the front of the engine is a chore, but not that bad in the scheme of things. A faulty design? Perhaps. I'd call it a compromise, where Rinker put more generous space in the cabin of a compact 25 foot boat and left little room for the mechanic.
Here's a tip. Removing the engine hatch isn't that hard. Then approach the front of the engine from the rear by laying down on the deck between the open engine hatch and the electrical panel. I'm 6'2" and this allows me a better view of the front of the motor, albeit it's not ideal and it is far from comfortable. As I posted before, a large mirror plus a good inspection lamp is a must.
Andy
Andy
