maiden voyage woes....
So....we went to bring her home on Sunday. The first 50 miles went without a hitch, Then, I noticed a very slight change in the tone of the engines, almost like there was less load on them. Next, the depth sounder started to flash on and off intermittently. Then we lost the port engine. The master alarm stated" low voltage sus" and the starboard engine was put into limp mode and limited to 1500 rpms. 20 minutes later, the starboard engine quit and we were dead in the water. The radar display went blank and we cell phoned for Sea Tow. We were lucky to get the anchor down as the current was VERY strong.
After many phone calls to the dealer and to the local Volvo service center, it was thought that perhaps by starting the generator and shutting down all the systems, perhaps we could get enough voltage to get her up and running. The best we could do before we got towed in, was get the starboard engine running again, but not out of limp mede. The port engine continued to just crank. Somehow, I was able to pull the anchor up by hand.
They still haven't look at it yet, but general opinion seems to center around electrical and not mechanical. As the radar and depth sound came back up after we ran the generator.
Ideas ? .......Thoughts ?
I'd present one went bad.. an alternator or a battery bank, and it killed the other, and because the load was the same but now on one bank/battery, it whacked it too.
Thanks for the input
Now, the fact it would "crank and crank" speaks of something else, though.
In not so many years ago, also known as the dark ages, regulators were separate from alternators... Then afterward, in the semi light ages, they were moved aboard the alternator... Now, they still have an on board regulator, but the charge is managed by the pcm. At least on cars... I'd guess on boats, too... Batteries require at least 13.5v to trickle, and 14.5v to burst charge... A pcm will monitor the voltage and adjust accordingly... So... A battery well charged will only take 14.5v as commanded.from the pcm for a few minutes and to recover from start up, then it will fall back to sustainment of 13.5 to 13.8.... and only increase as demand from battery itself increases.
I bet you have a bad connection somewhere, and your issue is that simple. A bad grounding strap on the block orpcm... A loose connection on a panel or blown inline fuse... I'd still have those alternators load tested, though, because like I said they've quite the reputation in the past few years and getting worse... To the point that I'd have one rebuilt by a good builder before I'd buy a replacement.
Explore7425, Thanks for the offer, I just found out that my NJ marina (who is Volvo Penta certified, is only certified on gas, not diesel......so at some point, if these problems don't get fixed after the batteries are replaced, I may hit you up for some help !!
