350 MAG Water Pressure/Thermostat OK?
MarkB
Member Posts: 3,997 ✭✭✭✭✭
Hey Gang,
Took the boat out for a spin this Sunday, what a nice day.
Anyhow, it's pretty much the first time I've used her since we splashed 3 weeks ago.
At idle my water pressure is around 0.5 psi, and at 4000 rpm it's around 7 - 8 psi.
I'm thinking that is a little low.
Coincidently not reaching 175'F. Getting close at around 160 - 165'F.
No alarms, runs fine, elbows and risers nice and cool after a good hard run.
My guess is thermostat is stuck open?
Given that I'm not "out of range" on any of the indicators, is this something I can
live with for the rest of this season (ie won't cause damage), and deal with when I haul
in October, or should it be addressed now? Can this be fixed while the boat is in the water
(need to pay $250 to get the boat lifted out of the water otherwise).
Assuming it is the thermostat - with the engine being in its 3rd season (2013, 2014),
and still under warranty until 2017 (extended), is this a warranty claim, or wear and tear?
Drew, where are you? LOL.
Best Answers
seguir Member Posts: 170 ✭✭✭
Then you might be right about the thermostat. Sounds like a easy fix. I always have a spare on board.
JoeStang Member Posts: 1,131 ✭✭✭✭
I had pebbles stuck in the tstat springs keeping it open. Now mine wouldnt eveb make the temp gauge budge, but I started to get gasoline in the oil due to running cold all the time. Swapping the tstat is a 15 minute job and doesnt need a haulout. I was told to make sure to use the marine gasket, as it has a built-in metal ring for grounding.
2013 276 Cuddy ~ 350 MAG / B3 -
212rowboat
Member Posts: 2,593 ✭✭✭✭✭
You gotta get a load on it to reach true operating temp. it'll idle up to and hold the stat rating w/o load, but until you work the engine, it'll never draw less than it needs (all things being healthy ).
Your PSI sound low at idle. Mine is about 40psi and 60 to 70 at 4000RPM.
So I have much better pressure. At 3000 rpm, it's hitting 10 psi. Was previously at around 7 psi.
So I idled for a while and the temperature levelled off at 160F. I gave it throttle to 3000 rpm and held for around 3 or 4 minutes. Dropped it back down to idle. Temp rose to 165F and then I saw it quickly go back down to 160F. It looks like the thermostat is doing that (went to idle, water pressure dropped off, so thermostat opened).
It's a 160F thermostat, but my mechanic said it would settle at around 175F.
Maybe I need to put load on it for 30 minutes or so to get the temp up. Not sure. The water in the Marina is 57F according to my fish finder.
Mark, just curious, where do you get the PSI numbers....I see no gage on my dash.
It's expected to have resistance.
The rods to journals can create gaps over time. The piston wrist bearings, same thing. chains under the front cover that manage timing by driving the cam in concert with the crank snap back when revving and no load, promoting stretching and possibly breaking, but risking jumping timing all the same.
Just don't do it, man. No matter the temptation, take her up to no higher than 2k and hold it to get to temp if you must, but don't rev it.
I just swapped stats earlier this spring. My boat runs around 178* or so at plane speeds north of 3krpm if the faria is to be trusted. That's a touch hotter than the last stat, but nothing I'm going to worry about. Last one ran a touch under 175. The one before that dead nuts 175.
I monitor my water pressure from my vesselview every time I'm using the boat. That and the oil pressure are the first things I look at when I start the engines. I've also had a hose come off when up on plane and that was the first thing I saw and was able to pull back and shut off before overheating. IMO, it's well worth having.
You should already have the sensor with Smartcraft.
