Searh light power
minnesotaminnesota Member Posts: 67 ✭✭
2008  280
Can anyone tell me which circuit is the search light connected to? I need to disconnect it temporarily  to reprogram the remote.
Th
2008 280 EC
    It should be a breaker labeled "Spot Light". The wire according to the wiring diagram is Red with an Orange tracer. It is a 15A breaker. The wiring diagram for the 280 is on here in the RBO Forum Archives section.
    Definitely the 12V circuit. Should have a breaker by the battery switch. You can also unplug the live power pin from the light, but you have to open the housing. Or you can just switch off the entire 12V circuit and ensure shore power isn't connected.
