That dreaded disappearing gear lube....
ok guys and gals my first post here... so I had gear lube disappearing out of my 2004 bravo 3 last fall to the point that my alarm would go off weekly. Nothing in the bilge but I saw the bubble and oil sheen in the water a number of times and had the boat pulled for the winter shortly after seeing that. The tech said he would look at it when he winterized my engine and fix the problem. He looked around the outdrive and noticed lube on the area where the upper and lower connected (it wasn't ultimately where it was coming from) so he did a pressure test and it passed with flying colors. By this time the temperatures had dropped to below freezing and the leak stopped (my guess is due to the thickening lube). Come this spring all was well until the day before I was due to be launched. That's when I noticed more lube leaking all over the pavement with temps finally reaching 70 degrees for the first time all year. They were stumped and at this point didn't seem to care as they said "oh that lube was there from before"...I called bull**** Long story short (too late)...with dumb luck I self diagnosed my problem. There was a small slit in the 10" hose connecting the transom to the drive. If I pulled on the hose it split open and dripped out rather quickly. Remember the lube looked like it was coming from the middle of the drive because it was falling out of the hose, landing right on that spot and running down the side. I put some rubberized tape around that slit as best I could to stop the bleeding. I was due to be launched the next morning about 15 hours later. The tech said no way we can get to that and launch you as scheduled. It was going to have to wait till later that week. Miraculously I was launched the very next day at 8am. I was told the guy that launches the boats did the work on my drive (after a long winter with this terrible marine dealer I'm completely skeptical at this point). NOW... I have the lube to the full line and ran the boat last weekend for 3 hours total. I lost lube to just above the add line but not to the point that the alarm went off (still a lot of lube) I topped it off to the full line again. Ran it today for about a half hour and down about 2-3 millimeters below the full line again. No oil slick in the water at all when I got back to the dock so where is it going now? Would there be that much air clearing the line after 3.5 hours on the boat and two separate times out on the lake? Ironically I just got the bill for the "hose fix" today. Do I pay it right away? Where should I go from here and how much damage am I risking to the drive if any at all? Sorry for the long explanation but it's been on my mind since last September so I felt it was necessary.
The oil line is only about 7 to 8 inches long and mercruiser sell it in 6 feet bulk.
