342 - How often to trim up?
This is my first bigger boat, had a 20 foot Sea Ray with an I/O, I worked the trim quite a bit on that boat when in shallow water. I am wondering how often you would trim up on a 342 in normal operation?
When you raise the drive too high, normally what happens is ventilation.
Luckily, that distinction doesn't matter in the current context. I'll edit the FAQ to say only that the propeller slips, and not speculate about the cause.
