No 12v Power at the helm
I'm in the middle of removing my dash and replacing with a replacement from a 2004 and seem to have no 12v power from the house battery after the work. Does anyone know how 12v power is fed to the dash from the house battery? Is it to the breaker panel and then fed to the switch/ignition panels from there? This has been causing me a lot of grief since I started. :-(
Any advice help would be greatly appreciated guys!
"Pipe Dream"
2002 Rinker 342 Fiesta Vee
2 x 350 MAG MPI Horizon Petrol
The rocker switches (lights, horn, windshield wiper, engine hatch, etc.) should be powered by the house circuit. There is also a breaker for that battery by the battery switch.
"Pipe Dream"
What is not powered, the gauges, the switches or everything? The gauges run off the ignition switch. The switches are powered off a bus under the switch panel. If you remove the panel the switches are on, you should see a bus probably on the left side of the helm.
Thanks so far Mark, big help!
"Pipe Dream"
Andy
"Pipe Dream"
"Pipe Dream"
ihave same problem after changing my starter
no 12v at all in my boat.
have you solve the problem?
We have a battery, switch, breaker, wire, bus, dash board.
For no power, obviously one or more has to the issue, and more
than likely only 1 is the issue.
Do you have 12V at your battery?
Do you have 12V after your switch?
Is breaker on? - the breakers are located in the battery switch panel. The distribution board in the cabin is for 110V only.
Do you have 12V after breaker?
Do you have continuity on wire at bus - to access bus, pull off the helm switch mount.
Is bus working - all connections intact?
do i have take batteryswitch out?
i dont no 12v at all in my boat i dont what happened after switching starter.
is it more breakers than that on the engine?
Rinker fiesta vee 270 year 2002 .
"Pipe Dream"
"Pipe Dream"
It most be an breaker at battery switch ,should more today after work.
So you should have two separate 12v feeds. One from 12v starter battery to battery switch. If this is good you should get 12v into the switch, check here first. Also check you have good grounding. Check out of the switch to the breaker on the battery panel. This then feeds the starter motor live via a 25amp fuse on the starter live terminal, this quite often needs replacing through corrosion.
The house battery should be direct to the battery switch via a breaker on the cabin switch... must have multiple issues for both to be out. Let us know what you find.
"Pipe Dream"
it was white plastic cube on the starter
jumpt it and its work 12v in the all boat
ididnt think that could take out all power .
thanks for all help guys.
"Pipe Dream"
Andy
The breaker on the engine take careoff problems if the come.
