over heating issues
i have an 06' 250 ec with the 5.7 volvo penta. what should be the normal operating temperature while running WOT? at idle? we just bought the boat in april, the first time we took it out we had no issues and while running at idle, we were at around 165-170, full WOT was around 200. the boat ran great and had no issues. last weekend we sucked up some mud at a local boat ramp that turned out to not be deep enough. now at idle speed we are around 180 but if we try to get up on plane, the temp starts climbing. i am assuming that i have a clog in my system and was curious as to where to start? i pulled the thermostat housing last night and noticed the thermostat was not present so that eliminated it possibly sticking. i just replaced the complete raw water pump assembly last week when i did my tune up.
other issue i had this weekend was with my air conditioner, it would pump water and the fan comes on but it wasn't getting cold. when i bought the boat through the broker, he had the ac running and it seemed like it was working fine. to back up a little bit on my story, i had no idea that the ac needed to be in the water in order to run, so it was on in my driveway for about 10 minutes when i first got the boat. (dumb a** rookie). did my rookie moment fry something? it seemed like the compressor kicked on that day for a minute but shut right off due to no water i assume.
any and all suggestions of help are greatly appreciated in advanced! i am a diy'er and really don't want to pay the 100 bucks an hour if i can avoid it. not too mention, peak season in northern Kentucky so the repair shops are swamped until after the 4th.
i also didn't hear an alarm going off when the temperature was rising. thanks
I don't think you hurt your a/c as the protection should have kicked in. Lots of guys run there aircon without the water pump being primed.
1. Blocked manifolds or risors due to corrosion. Overheat under load
2. Bad seal in outdrive between pickup and sea water pump allowing it to suck air on plane, but not submerged.
3. The rest of the impeller got stuck in block, manifolds, or risor.
found this info on line
when i flushed everything, i pulled the plug from the top of the heat exchanger and the hose off of the raw water pump. started at the plug to blow anything that might be stuck back towards the raw water pump hose, and then reversed the flow. i did that several times as well as pull the hoses from the power steering oil cooler.
once i get a thermostat back in the boat, calls for 170, what should i expect to see at WOT for my normal operating temperature?
170? Strange number... are you closed loop cooling the engine (without looking back to see)?? If not, it should be 160.
your safe ceiling for temps at WOT and extended period is likely right at 195. If you're closed loop cooled, you can safely go higher; it can't flash boil because it's pressurized. If you're raw water, it CAN flash boil, and you'll want to be safely under that point... 212* at sea level, but different (lower) at altitudes... If it's not sea level, I'd not wanna see north of 190* EVER.
you need to be slightly more concerned at 3/4 rather than wide open throttle. Reason: the engine opens loop and pumps fuel at the maximum rate at WOT, and will run rich because of such- rich is cooler than lean. At 3/4 throttle, the engine is managing fuel and trimming it, which means it will be closer to stioch, which is leaner... and leaner is hotter. If temp spikes, then you aren't circulating enough water, and the circulation pump likely needs to be changed... it's not like a car which has a big heavy clutch fan hanging off the front of it, and seals that will rupture on that shaft giving you a heads up it's checking out of the game, you'll find it first by temps that the impeller/paddle has worn to where it's not pushing enough fluid.
If you're efi/pcm, you're gonna want to make certain and use the right thermostat. The engine expects a certain temp and range to trim fuel properly. Ten degrees makes a difference.
Temp sending unit, Volvo penta through local dealer- 73 dollars(not in stock) Standard brand through a friend at the local auto store. 11.98 with tax. Thanks 212rowboat. Have to wait for the river to come back down from all this rain before I can test under load. Lake Cumberland trip scheduled for next week so hope all is good. Now time to fix the air con
