Does anyone know if the 342 has a holding tank vent filter and if so what size? I see they are available in 5/8, 3/4, 1 1/2. I am looking to add one or replace one if there is one installed stock.
Haven't used it. Same concept I guess. Only thing is it's missing a vacuum relief. If you have too much suction on the pump out, that may restrict the vent enough to collapse your tank. The big orange does have a vacuum relief on it.
yeah, build your own. 5/8" is the size. I've probably built a dozen of them now for various people. I'm sure the airforce one works fine, maybe you can cut it and reuse when it stops working.
http://www.westmarine.com/buy/sealand--sanigard-holding-tank-vent-filters--P000447144
http://www.amazon.com/AirForce-Holding-Replacement-Dometic-SaniGard/dp/B00H7HO97E
Ray
2006 390
Previous 2000 340
