Bottom coat, remove?
I have an 05 270FV with the 350mag MPI. As you guys know, she's kind of a dog getting and staying up on plane. It has 22pitch props. We have been keeping in the dry racks instead of sitting in the water continually. The bottom coat that is on there was from the previous owner and is a little below the fresh water line. (Seems proof positive this boat was actually kept in salt water previously, contrary to the seller's claim). But, I'm wondering if it would be worth while to strip the hull of all the bottom paint to help improve performance ?? There is a barrier coat as well. Wondering if anyone has had experience with this?
Thanks!
Thanks!
Ours runs like a champ and I'd say that it's because she has been well attended to her entire life (and I've learned a few tricks that this boat needs re trim and weight distribution). GSL has a good point that if your 270 is lacking in performance it's either needing some regular attention or your expectations are too high for an RV of a boat. If you think it might be the bottom paint, get a respirator and haz suit on and take an hour to hit it with sand paper to knock the texture off. It's really very simple to get it somewhat slick unless it's 14 layers thick (doubtful) which you should strip off later. If ,as you suspect, it was a saltwater boat then the bottom paint is probably ineffective in your region anyway.
Otherwise unload the weight from boat, taking everything off that you can imagine including emptying holding tanks and a light fuel load. Move other items amidship or forward, change your fuel filters and run it with a half filled tank of something non-ethanol and high octane. If it won't (relatively) jump out of the hole (assuming you are trimmed correctly running in neutral seas and weather conditions) in 6-9secs then there's more to it than bottom paint as GSL said.
Good luck. Mike
Thanks for your comment. I imagine it would be difficult to compare apples to apples, as I will likely never see the same conditions on Lake Erie as everyone else on inland waterways. The bottom paint on mine is from the previous owner, so I'm not sure what kind, but it looks pretty beat upon places and doesn't look increadibly smooth. I was planning to eventually hit it with a random orbit sander to Atleast smooth out some of the rough areas that developed from being put on and off the trailer.
