342 Help
So I just bought our boat 3 weeks ago and found tons of problems when I got it home.  Longstory short both port and starboard motors had dead cylinders and ran rough.  We have tore down both motors and rebuilt top end with new valves, machine work and injectors.  I had #5 cylinder on both engines were 25psi starboard, 8 psi port side because tuliped valves.  All others were 125psi.    Either way, just finished getting it back together however the starboard motor still stops producing power around 3500rpm,  the boat will run right up to it and just stop or the throttle will make power till about 3/8 and there is no difference from there to wot.  Any ideas, no alarm.  Port side seems to be fine, she will scoot to 4000 with half throttle and plenty of torque / power with each tap of the throttle.  I don't want to run them that far out of sync so 3500/4000 is the best i have seen yet.   Starboard gimbal bearing seems to have taken a dive, could the knock sensor be picking up the noise and retarding the engine?  Anyone in Cleveland Area with a Rinda Scantool?
