Broke down today... Need suggestions please
diggin2day1
Member Posts: 1,331 ✭✭✭✭
So here's the full story.... We bought our FV270 this winter and have been using it like crazy since it hit the water in May. Started the season with a full(100 gallons) of fuel, burned/added 50 gallons a few weeks ago. We burned 70 more gallons in the last few weeks and intended to get fuel on the way home today. We were on our way to the fuel dock cruising at about 28mph and the boat was slightly porpoising due to chop/too much trim. To knock down the porpoising I trimmed it down a bit and heard the RPMs drop slightly and heard the engine change pitch as well(like it always does when it's not trimmed into the "sweet spot")... At that instant RPMs dropped way off and the engine started to sputter. I tried to get the boat moving again as we were about 1/2 mile from our marina and it sputtered/bogged then died as I pushed the throttle. My analog fuel gauge on my dashboard read "empty" but my charplotter(linked to engine via smartcraft) displayed 23 gallons left in tank. My first though was that I ran out of fuel and my chartplotter was WAY off. Luckily my buddy was following me and went and got 5 gallons of fuel for me. I added the 5 gallons from him and was able to get about 2 more out of my dinghy's outboard gas tank. I tried to restart it a few times but it quickly sputtered out again. We transferred our kids to my friends boat so they could go back to marina and we called SeaTow. After waiting for the SeaTow captain for about 5 minutes I tried to start it again.... Started up and ran fine! Went straight to the fuel dock and filled her up with 77 gallons of fuel.... My charplotter was DEAD ON! After refueling we got back on plane and cruised with no problems whatsoever.
One thing that made me nervous was the instant before the engine died(while it was sputtering out) I glanced at my oil pressure gauge and it was very low. Thinking that it was low due to sputtering/low RPM of engine(I hope!!!)... There was no alarms or warning lights at all. After we restarted the oil pressure was reading 50psi on analog gauge AND on the chartplotter/smartcraft.
I was obviously not out of fuel... Any suggestions?!?! Fuel/water separator?!?!
Altering trim altered load while pcm had increased advance, which promoted predetonation. Good fuel wouldn't have done that.
If my suggestion is accurate, and you knocked the knock sensor, the pcm protects the engine until certain conditions are met. One of those conditions is temperature.. The pcm figures the temperature could be the cause of knock, so, no go go till cool cool.
Fuel quality, or lack of, will allow predets easier than good fuel... Nearing the end of the tank you're likely pulling fuel with drops of water, which is unstable and more likely to predet... that, in addition to running consistent speeds/load, allows the engine to advance timing to the edge, quickly altering that by adding considerable load (down trimming, changing angle of attack) in the split second likely caused a few knocks, and serious enough to trigger the pcm's protection mode...
This is all speculation, understand, but it's consistent with what you encountered.
If youve got access to a scanner, knocks are logged, too..
