Was the initial prep for bottom paint done correctly?
Hey Everyone,
Looking at the bottom paint that has chipped away and exposed the white hull I can see that some of it still has a glossy feel and does not feel sanded. My concern is that this is not done correctly and will blister. I have a few pictures but not sure you can tell. The white is not rough but smooth.
Patrick
06 Rinker 270
06 Rinker 270
There's no doubt, the manufacturer (Interlux) recommends a rough surface for barrier coat. They recommended that we sand blast our bottom. We did not remove all the gelcoat, just roughed up the surface and cleaned the mold release agent off.
After that 4 coats of Interprotect Barrier Coat and 2 coats of Micron CSC (VC17 is also good).
I had to raise my coating as the water line was going above it towards the back. They did not sand the raise properly and it basically all flaked off in 1 year. Not the original bottom, just the raise (about 1 or 2"). I had someone else redo it. They stripped the old paint, sanded properly and reapplied. I'm in my 3rd year, and the undercoat is sticking like crap on a cottontail. I haven't even had to touch up really, just in places where we knicked the anti-fouling during haul out.
Has anyone had issues with Rinkers blistering or know if they had issues in the past?
06 Rinker 270
06Rinker - when I had to fix my raise, we had to strip the old raise off, and even some of the original bottom to be able to blend the new barrier paint in properly. There are many companies that will offer to strip and repaint the bottom, it's a fairly common practice, especially when people don't know what is on their bottom paint and would like to start with a clean sheet. I wouldn't worry about it too much.
Every boat is at risk of osmotic blistering. But I can tell you my gelcoat guy (who is always busy with gelcoat, fibreglass and paint) indicates that he rarely sees issues with Rinkers. The risk is generally low. I believe the gelcoat technology has improved in the last few years, and that osmotic blistering is less of an issue today.
I know there is risk, and you may be concerned, but if it were my boat, I'd probably just leave the job for the fall. It will probably take you a month to find a good person, get a quote and get them booked anyhow.
I am currently on a lift but I am going to a wet slip here in early August. As you all agree the bottom needs something before it goes in. Do you think its ok to just sand and repaint(which I will do myself) or should I do the barrier coat.
@Alswagg Do I remove all the bottom paint by sanding or do I do a chemical strip.
06 Rinker 270
What barrier paint are they using?
06 Rinker 270
06 Rinker 270
06 Rinker 270
06 Rinker 270
06 Rinker 270
06 Rinker 270
