2002 Rinker 342 Bravo 3 ratio
Irocz18Irocz18 Member Posts: 5
Hi Guys,
blew a drive on my vessel and looking for a new upper. There is many different ratios. Does anyone know the ratio they used for the 2002 bravo 3 drives? I think 220 but not sure?
    You can enter your drive serial number into the Mercruiser website and it tells you what ratio you have.  It's located on a metal tag riveted to the drive or on a decal.
    Should be on the sticker on the drive. If you are lucky. If you blew the upper, you need the lower redone too. Where are you at?
  • Irocz18Irocz18 Member Posts: 5
    They said the upper was the only one that was affected hopefully. I am not sure that the serial# is able to be read on the drive as this "was" a salt water boat. I will have to take a look at it again. I am located in Rochester, NY
    If you got metal fines/pieces it went to the lower unit too. There is even less room for error in the lower case.  If you are willing to ship the drive, contact alswagg on here or www.allamericandriveservice.com
