Engine Repower
CrewLounge
Member Posts: 92 ✭✭
Time to repower the 6.2's in my 342. Any recommendations on who to use, which rebuilder, Mercruiser Reman, etc?
Veering back on topic ... assuming CrewLounge's engines are toast, what's a good strategy for a rebuild?
on my 6.4L powerstroke diesel I am silly maintenance minded. I've never ran any more than 5k miles on it w/o a change of both filter and oil.... It holds 15quarts... I run high quality synthetic (Schaeffer's 9000 group four full synthetic cj4 in 5w-40)...
I usually turn black around 1.5K miles.... Even though analysis perks out well, I still swap it at 5k miles regardless. using a zddp based oil, when it goes bad, it goes bad quickly, as the compounds separate and fall off of hard parts.
anyway, I introduced a bypass filtration system on that rig... it sips 10% of the flow and funnels it to a 2 micron absolute (@98% efficiency) filter, before reintroducing it to the engine. The filter is marketed by Amsoil. I run the 100 model.
So... I JUST sent in a sample to Blackstone this morning of an oil with 9800 miles on it. I would never have ran this long on ANY oil, but, the stuff is still pristine, with only the hint of black ash present. I want to know how the detergents are holding up, which is the reason for the analysis.
9800 miles.... absolutely crazy to me....
oil doesn't break down, it contaminates- and when the contaminants exceed the lubrication properties is when you should change it... this oil is still green (Schaeffer's has a green tint to it) more than black... The compounds in the oil intended to protect DO expire/break down, which is the only reason I sent in a sample.
A bypass oil system can easily be introduced to these engines- and it would be worth it.... Al, that engine you're swapping oil on every two weeks? You could likely extend it to monthly or even every other month.
I didn't take this venture lightly, I researched and researched, did a lot of sampling and determining there was no fuel dilution or excessive blow-by from combustion gasses indicating engine issues, or water infiltration due to not reaching temperatures capable of burning off moisture, ect.... I researched like my trucks engine depended on it, and it kinda does... My only regret is that I waited until 90k miles to introduce it...
fellas- consider the by-pass system...
to put it into perspective, some over the road truck maintenance guys are reporting 400k on ONE oil change interval, using lab results to coach them every 25k miles, and swapping when the analysis indicates them to do so... this is up from around 40~50k miles usually... these guys make their living off of their trucks- keep that in mind, so they aren't going to do something risky... this saves them not only engines longevity, but a LOT of money swapping oil (those things hold like 14~15 gallons of the stuff), and not to mention, doing a good deed for the environment.
