Empty housebattery
Hello
My house battery 2*80ah. was empty after 12 hours .,the only thing was on is the fridge.
Can the fridge be the problem ? its workning good when it has Power. i have tested with 2 battery setups and the same problem.
Its an Isotherm maybe from 2002?
Anyone has same problem? if not what can it be taking all the Power so quick.
My climate is warmer than yours, obviously.
Andy
Fridge should empty my batterys on 12h. it most take a lot of Power to empty 2*80amp batterys something most be wrong.
It is fridge take all the power for me ?nothing else is on.
somthing wrong vhit the fridge maybe but what?
Depending on a few variables - 12 hours isn't bad for 2 80 Ah batteries as that they wouldn't have a lot of duration - particularly depending on HOW they are wired. Are the batteries wired according to the diagram Frenchship posted a week or so ago? If they are you will get a lot longer duration from your Ah rating (almost twice as long depending on the battery chemistry) than just the 160 Ah you will get if the boat's + and - lead go to the first battery with short leads going straight back to the second battery. What type of battery chemistry do you have? Flooded Cell? Gel? AGM? The chemistry makes a BIG difference regarding longevity! I assume both batteries are deep-cycle. As an example I have series 31 AGM deep cycle batteries with 105 Ah each, wired properly. That gives me the equivalent of over 600 Ah. I can run two fridges ( a 2.4 and a 4.2) at 3/4 level plus a couple of fans, my lights and some use of my 12v TV for 12 hours, easily.
ok
The fridge is defrosted and the batteries are ok .can it really drain mine 2 80 ah batteries so Quick ? thats sounds nearly impossible.
http://www.myswag.org/index.php?topic=13578.0
So 2 x 80 Ah batters = 160 Ah total = dead in 11 to 13 hours if the fridge is the only consumer of power. Turn on your radio and a few lights and you would drop below 10 hours duration.
Michael T that is closed batteries and just ordinary batteries not agm or gel.
MarkB fantastic if they take so much power idont now if its an 90l. or 65l. fridge.
Iam surprised but that lot of power use i understand why the batterys ar empty after 10 h.
120 W / 12 V = 10 amps.
Now, I believe this is the power consumption when the compressor is running. So that depends on how much warm air and heat enters the fridge. If it isn't opened, than probably it will work like 20% of the time. But if it's opened every 10 minutes, count on the compressor working 80 to 100% of the time (depending on your thermostat setting).
The other thing that you might want to look at is your fridge seal. This isn't really about changing your fridge (they all consume about the same amount of power), and although you might need to upgrade your batteries, no matter what you do, if you are letting warm air in, and that compressor is running all the time, you are probably reducing battery duration by 3 to 5 times. So check if it is sealing properly.
Gone look at seal and testing it how much power takes with an multimeter.
We are achoring a lot 2 to 3 days
If you could manage both now, I would - but how old is your fridge? Make sure if you get another one, you are cutting consumption by at least 30%, or it really won't make a difference.
As has been aid a newer fridge probably won't make much difference on power consumption but better batteries will be useful for ALL of your electrical needs.
New 12v.fridge just use about 1.5 amp average so my batterybank should last for few days maybe.
The fridge are maybe from 2002 when the boat was new.
For me is nearly unbelivible that it take so much power on 12v.
I recommend Series 31 AGM (Absorbed Glass Mat) If you spend a lot of time at anchor running from your house batteries I would get 3 AGM series 31 batteries. If you have the room and can afford them.
Although I fully agree AGM's are the way to go, Swede's boat is a 2002, his starting batteries are more than likely flooded lead cells and I highly doubt his battery charger will be able to differentiate different types on different banks.
I would suggest leaving the fridge as is, and adding 3 flooded cell group 31 batteries. As MT already stated, adding new batts, will benefit ALL your electrical needs.
a new fridge about 650$ 3 new agm batteries is lot more $.
We can only provide you advice, but of course, you do what you feel is the best for your situation.
I just don't think you will solve your problem, if you are worried about the fridge's battery drain. The new fridge won't be that much better. Compressors are very old technology and haven't really changed that much even on the new energy star systems. Advancements on 12V gear is even worse.
Anyhow, I think you will solve your problem better with batteries. If 3 x 31D batteries is too expensive, then install 2, and leave space for a 3rd in the future.
Andy
Swede,
I fully agree with MarkB. Also....the price for flooded cell 31's is significantly less than AGM's. As I stated earlier, I replaced my 2 group 27's with 3 group 31's and was very impressed at how much juice I had left after 28hrs......and remember, I'm running 2 fridges.
