Mercruiser Single Beep Only in Reverse
Malloy
Member Posts: 42 ✭✭
I consistently get a single long beep from my 2011 twin 350 mags. I have isolated the beep to the following condition:
port engine in reverse (at roughly idle speed)
straboard engine forward (at roughly idle speed)
It happens every time I dock. I have checked fluid levels, pressure, temps etc...
This season is the first it has happened. I was actually thinking it could be my depth finder?? Is it possible the this combination of engine direction is causing a disturbance in the water that would signal low depth??? Just a thought. I can test this weekend by turning off the depth finder.
Any other thoughts or advise would be appreciated!
The engine, while going into or out of gear, momentarily cuts ignition as it doesn't have any other way of dealing with stall... Pretty slick design... The other engine running and that one momentarily stalling as it should likely has just the right bounce to it to announce itself as a knock, then quickly change its mind when ignition is re-applied...
For this to be reasonable, it'll have to be doing it just as soon as you touch neutral or reverse.... Is that when it happens?
