Faria Transducer, again!
Gauge keeps reading 4 and 198 ft. and sounds the alarm. Called Faria who said transducer is likely culprit and buy a new unit. Read previous post on replacement but looking for steps to do it.
Do you have to replace the unit with the cable by snaking it to the gauge (p.i.a.) or just a splice with the new one?
Pulling the boat out to swap out a Lenco actuator so I might as well tackle this issue while its out.
Any comments absolutely appreciated but please don't tell me to dump the matching instruments!
To be honest, I don't ever pay attention to my faria gauge anymore. It is a weak system. I put on a fishfinder and ran a transducer on my transom. It is way more accurate. Those transducers need to be replaced every 5 or so years, so it's WAY easier to replace on my fishfinder. Why don't you consider that?
You suggest good reasons to go that way and even the Faria tech suggested to me to substitute a shoot threw the hull transducer and leave it alone rather than replace it.
Just gets me to do it but I may have to!
But you can't let OCD make you do something, well ... dumb. The Faria transducer/depth technology SUCKS. Put in a better head unit, that seconds as a fishfinder and/or GPS. Put in a much better transducer. You will be able to track bottom much better at 30 mph than that Faria gauge will ever allow you to do.
If you don't want to see a non-functioning gauge there, then figure out something else to use that space for - put in a media station (auxillary in, USB in, 12V charger, etc).
Don't waste money on a poor solution.
I found one for $41 with 26 ft of cable and thought it would be a simple swap out except for fishing the cable and that was based on a previous post I read here.
Thanks for the feedback! You've got me re-thinking what to do.
