Hydro Locking confusion
My mechanic has been working on my boat since June 22nd due to getting an alarm on my port engine. It was getting hydro locked and they kept thinking they fixed the issue. Here is what the guy is saying now. Just doesn't make sense to me (please advise or point me to a good mechanic in the Annapolis, MD area that can/will help)....
We had it fail to start and hydrolock on us today for the first time so we got to see what you are seeing. The water came in through the exhaust when the engine tried to run backwards a revolution or two during a backfire. The cause of the backfire is the same as what was preventing the engine from starting consistently. We believe the cap and rotor was shorting out and causing the misfire. The boat started consistently since the repair. Going back to the discussion about the water incursion, It is concerning to me. The factory exhaust height may need to be raised 3 inches and they make a kit for this but it is not cheap (2,500.00 parts and labor). The original problem was the two failed injectors. The manual cylinder drop test confirmed their failure. Their replacement and seatrial confirmed that this part was fixed. We replaced the cap and rotor on both engines and the starter and exhaust gasket on the port engine.
