342 RINKER WITH ONE ENGINE BATTERY AND ONE FOR THE GENNY NEED HELP
I went on a 4 day mooring weekend with friends.my genny would not start.when i went back to my marina a friend with mechanical background troubledshooted .he said the starter battery located near the stern started the engines and was being charged by the engines/shorepower.the other starter battery located in front started the genny and was only charged by the genny.i dont use my genny very often hence it was low from the draw the gennt has from being in the ready position . he suggested i close the genny if im away for a few days . any ideas on how to proceed are they all connected this way . he did make a suggestion to connect both positives with wire that has a one way fuse /diode tks
On my 342 (2005) I have 2 starting batts....one for the stb engine and the other for the port and genny.
With all due respect to your friend, you should hire a qualified marine mechanic to inspect the wiring. It should be like DanD2 said: one starter battery for stbd, one for port + genny.
My 342 has 2 batteries for starting, as noted by others. No seperate battery for the genny.
