Need tips for backing into slip
l-skynyrd
Member Posts: 178 ✭✭✭
For the 6 years I have had my boat I have never backed into my slip. My slip has two fingers and the shore power is on the port finger the same with the boat and we fish off the back also.
I have reserved a guest slip in San Francisco (70 miles away) for Fleet Week. Not easy to get so you take what they give you. What they gave me is a double slip. Two boats with one finger each. For ease of connecting and dis-connecting the shore power and getting on and off the boat I want to back into the slip. I will have the finger on the port side and another boat on the starboard side.
I would like to get some tips on backing into the slip. I will practice these tips at my slip to get used to backing in before trying it with someone else's boat next to me.
I know many of you are experts at this so please help me out. I promise to post lots of pic's.
Len
Len & Robyn 342 FV Freebird
Andy
Andy
No matter what do not panic. If you have to nudge the boat beside you, it won't cause damage. Damage is caused when people panic and gun the throttle.
Do you have one or two engines? If 2 it makes it easier with a bigger boat. I am used to a single engine on my 232, which is easy to maneuver being a smaller boat. When using my bosses 340 Sea Ray back in June and backing it into the slip for the first time, I used forward or reverse on each engine to steer or change the attitude of the boat, especially if you have waves or wind. Mark's feedback is golden about going slow and having helpers. If I can do it so can you. Once I was out of the slip the first time I practiced backing in open water to see what worked bests for maneuvering backing up. I backed the 340 in each time out without incidence. I was a novice that had the same fears as you.
Thanks Mark and Andy for the replys. You guys did not see at the bottom of my post that I have a 342 FV, which has twin engines. I will have some crew to help and I always go as slow as I can when ever I am docking.
With twin engines I am thinking I need to determine the pivot point of the boat and where to position the boat in relationship to the slip when I start pivoting the boat to line up with the slip.
Len
Makes backing in much simpler for me.
I start down river about 3 widths away from the slip and have the prop "pull" me into the slip...not unlike drivng a forklift in reverse. I "bend" the hull around the corner. More often than not I am able to slide in without touching the bumper wheel at the down river entrance to the slip.
As others said, slow is the way to go.
Practice a couple times and you'll find it is pretty easy.
Oh, our 250 is a single with dual props.
Yes, all advice here is great! I will add, after you get the hang of movement without using your steering, then note that the use steering can actually help. For example, just today when I was backing in, my aft port side needed to shift quickly more port so I miss a piling on my stbd side. I turned the wheel clockwise and gave a quick forward port engine thrust. Move my aft right in place. I pulled into the identical slip today you are talking about. I think you've been around enough you will be just fine.
Oh one big thing I forgot and makes a huge difference. when backing, completely turn aft at the helm and operate controls with left hand. Controls will work in direction you are facing. If you need to turn wheel, top of wheel goes in direction aft will go in reverse (bow moves opposite).
Approach the slip perpendicular and place one engine in forward and one in reverse to turn the boat. I always do this until the boat is turned about half way. Then put both engines in neutral and turn around facing backwards and re-access your turn. Then you can pretty much just bump one engine at a time either forward or reverse depending on what you need to do. Imagine a dot directly in the middle of the slip and an arrow pointing straight back from the middle of the boat. If that arrow is pointing toward the slip dot then back her up. Doesn't matter if the boat is turned too much either way because you will correct that once you get within a couple feet of the slip. As you turn and that arrow lines up with the middle of the slip, back her up a little then put both engines in neutral and re-access. Correct until lined up again then back her up again. On the 342, placing just one engine in reverse will pull that side inward if that makes sense. So if you are a little too far right then put that side engine in reverse and it will pull you a little left and vice versa for the other side. When you make the initial turn, you want the backend to swing around no more than 5 or 6 feet from the slip opening. The less distance you need to cover once you get lined up the better, especially in wind or current. Remember this.....Neutral, re-access, bump an engine, neutral, re-access, bump an engine and repeat. And when you get her lined up perfect, go with both engines back.
