Bravo 3 oil
Can i use another oil to bravo 3 than Quicksilvers high performance gear oil ? its cost a lot.
Ok same use for me to on the boat.
If there is no water in the oil then i can use it again on this low hours?
After plane 2 hours gear oil disapre about half resovair.
What can the problem be. getting to hot upperhouse?
There are better oils than the Mercury 'blue death' oil. None are cheap.
I have not seen any thing in the water and now leak on tube i think. the oil is clear
in the reservoir. no water in it.
I have not any sheen but i have not wait so long to look for it.
Got to look it up. I filled up 3 times so i think the air most be gone.
If the prop seal is leaking is gone show on the water after a time?
I can not see any oil in engine room.
