Bimini support strap
bat32
Member Posts: 161 ✭✭✭
Ok, so today while anchoring at the beach the Admiral and her sister decided to put up the Bimini top. Well up the top went and over board went the bottom part of one of the support straps. The plug in buckle must have come undone and we found out the hard way that the strap doesn't float. So I go to find a replacement online and can not find a single one that fits the design of our top. Please help. All I can find are ones with either a D ring or a small hook at the end that attaches to the top and we need just a loop stitched in the webbing. Does Rinker carry these straps?
Best Answer
trich11
Member Posts: 108 ✭✭✭
Contact at Ameritex is cfoster@ameritexfabrics.com
Chyerl Foster (correct spelling)
2019 MTX20 Extreme
If you look on page 55 of the attached catalogue, I believe you need the side release buckle shown. If you get this strap...
http://www.iboats.com/Seadog-Bimini-Strap/dm/cart_id.303337974--session_id.696110148--view_id.39808
then any upholstery or top shop can stitch the buckle on.
Mark
Mark
2019 MTX20 Extreme
Wow Mark! thanks for the research!! I did see a couple of nice straps with the upgraded hooks but like you said; I would have to have an upholsterer stitch on the buckle. If I have an upholster stitch it I probably will just have them make a loop in the end so I can just girth hitch it around the top bar and negate the buckle all together. Not sure why they made this a two piece strap I the first place (any one with camper canvas please chime in). On top of it, the strap was an off white so I will have to replace both if I can't get a factory replacement. Ugh!
I am going to see if Ameritex has anything today if I can get a hold of them.
Don't forget to give TJ (Boattech01) on this site a shout as well. He may have extra straps.
Mark
2019 MTX20 Extreme
Just post to this thread.
http://rinkerboats.vanillaforums.com/discussion/308/rinker-canvas#latest
Rinker Parts Dept.....email Malary at mwagner@nauticglobalgroup.com
Mark
2019 MTX20 Extreme
Excellent info. Thanks. Glad you found a source.
Mark
2019 MTX20 Extreme
