186BR with Mercruser 4.3 MPI prop selection.
Deadeye
Member Posts: 9 ✭
This boat came with a 23 pitch High Five prop. The issue is that the engine easily over revs with this prop even withe trim all the way down. I get 47 or 48 MPH at 4800 Rpm and 3/4 throttle. What prop should I consider for best top speed?
Mark
2019 MTX20 Extreme
I also have a 2014 186 4.3MPI 220hp mine is fitted with a 23p 14" 3 blade alum prop
my hole shot is lousy but top end is good at 50mph
I am changing to a 4 blade 21p stainless vensura mercury prop
will let you know the difference in a week or so.
btw I am down under in Sydney Australia
have fun love our Rinker great boat and great fun
cheers
Larry
Thank you for the information and I'm glad to have made your acquaintance.
I can't help but think that this combination could do over 50 with just the right prop. That being said, I have blown my boating budget for this year having just bought the boat so a new prop may not happen.
There are some small issues with my boat, I'm wondering if you have any of these too:
- There is a hairline crack developing across the floor in front of the rear seat.
- The exhaust riser on the port side is hitting the fiberglass rail under the sun pad, causing vibration.
- The volt meter is not working.
I am in Canada eh, east of Toronto so the boating season is starting to wind down. My Rinker will be out of the water by mid October. I'm sure you will be having fun with yours when mine is covered with snow (sigh).Deadeye
Hairline cracked I would speak to dealer about. That should be under warranty as well.
I'm also from Oz, Lake Macquarie. glad I have company Down Under. From new (2015) I had the same prop as you. I am very interested how your new prop went. My 186 has bad cavitation when laden and I am hoping a new stainless steel prop will help. Looking forward to your report.
Greg
I now have the winter to consider props as my boat is put away until spring, (late April or early May here in Ontario, Canada).
well I fit the Vengeance 21P 4 blade stainless prop on the 186BR 220HP and what a difference it makes hot shot is very fast even with a full load lost about 3kph on top end but that's nothing still getting 80 kph handling in corners is great it just digs and goes anyone in OZ near Gosford happy to lend it for a weekend to try it out best investment (after the smartcraft gauges).still loving the boat.. one question re the vinyl seats how do you get and keep them white they always seem to look dirty even after a good clean but afraid to scrub them too hard any advise would be appreciated.. happy boating
@Deadeye and lightlarry, out of interest what is your gear ratio? 1.81:1 ?
