Captiva 192 Worked 4.3L hitting Rev Limiter at WOT. Which Prop to fix.
I just bought a 99 Rinker 192. The engine was professionally rebuilt last year. Bored 0.02 over, Edelbrock intake, edelbrock 4bbl and Comp Cams. The shop that rebuilt it estimated 240+hp. The boat currently has a 14.5" 19p on it. It gets on plane quickly but hits the rev limiter at WOT.. I would like to get a little more top end out of it and be able to run WOT without hitting the rev limiter. I will be ditching the whale tale and installing Smart Tabs this weekend to help with plane time. I suspect a 14.5 21p will be the right prop I would just like some more input before I lay down the cash for a new prop.
Thanks
Thanks
What is the WOT max rpm? As the throttle is advanced, when is the max WOT rpm reached and how much throttle is left?
Good call on the hydrofoil......
Mark
2019 MTX20 Extreme
Mark
2019 MTX20 Extreme
if you can find a merc dealer, they may still have some blue props, which were meant for potential customers to test them out before dropping coin to buy it.
Mark
2019 MTX20 Extreme
Mark
2019 MTX20 Extreme
Thanks,
The big discrepancy between you and I here is that I haven't had any trouble with rpm's. I've never gotten close to the rev limiter. I have been at ~48-49 WOT via GPS with good holeshot all the while under 4000 rpm. I was actually considering going to a 17 for this next prop but decided I'd prefer the Solas vs Turning Point comparison. The plus to TP props is they're only like $90 since it has a modular hub. I figure once I sort out my specs, then I will jump to an elite prop.
I really wish there was a boat dyno! I'd like to know how this motor is actually running. It runs perfect, supposedly at ~100 hours now- but who knows if I'm getting 220 or 180 hp. I might consider pulling the motor for a dyno run, but the V-P controls would have to be taken along, and I'm not up for going that far. Anyway, according to a review I read, it should have planed much quicker stock than it did. With Smarttabs and 4P prop, I'm planing about as they claimed in the magazine/online article.
This doesn't answer any questions, but does offer some other perspective. I'm coming to believe that each boat is indeed unique. Build it the way IT needs to be built. If you're hitting the rev limiter- go up in pitch. I recommend the 4P as it offered better bite when cornering and better holeshot. Going to 4P, I understand it's common to drop in pitch- my experience agrees. Given that you need pitch, maybe keep the same pitch, just switch to a 4P. I've done a fair amount of research and found that ultimately it's trial and error. Tables might give you confidence, but the water tells that tale. These are expensive lessons- my pockets aren't deep enough to learn in SS.
FYI- Turning Point has a pretty thorough prop selection tool. It responded with exactly what I came looking to buy. Their props are unique with 2 different pedal profiles- very anxious to see how it performs.
I get it at times, but seems more prevalent when cruising and occasionally when wakeboarding. I was attributing it to one of the tabs folding and the other one doesn't. A good curve the opposing direction usually levels it out. This is what I've come to dislike about the Smarttabs. I'm working on different setting the tabs left to right.
