Impeller Question
I was getting high raw water pressure readings on my Port engine. It is a 2014 Mercury 8.2 Magnum - closed cooling with raw water cooling in the heat exchanger. In the end it turned out that the sensor was bad and it was replaced. Before that was realized the technician replaced the impeller in the raw water pump. It looked like he had to force the impeller in. I asked him if he had gotten it in backwards. He said there was no such thing and anyway if it did go in backwards the fins would just reverse. Today at the end of a 7 day trip I got critical low water pressure warnings on my vessel view for the Port engine - and a warning to return to my slip immediately. I shut the engine off right away and docked the boat. When I got the boat secured in the slip I restarted BOTH engines. There were no more alarms from the Port engine BUT it was operating at half the water pressure of the Starboard engine all the way from idle to 2000 RPM. FINALLY - the question. I just looked at the impeller the tech took out weeks ago. There is no question that the fins are all pre-formed in one direction. Is he right that if he installed it "backwards" that the fins would just bend in the right direction or is he full of cr*p - 'cause it sure doesn't look like the fins will "bend" to me. Advice appreciated.
Mark
2019 MTX20 Extreme
