What are these?(additional anodes)
edited September 2015 in Generator Discussions
I have two of these under swim platform below water line. There is one on either side of the drive.
Patrick
06 Rinker 270
Post edited by 06Rinker270 on
  • aero3113aero3113 Member Posts: 9,540 ✭✭✭✭✭
    I believe they are your mercathodes.
    http://www.sterndrives.com/mercathode.html
    Ah yes, they are transom mounted anodes. I guess they are additional to the one connected to the gimbal housing?
    Patrick
    06 Rinker 270
    It's hard to tell rom the picture but they do not seem to have the proper surface appearance to them. Yours is a salt water boat? So these anodes are zinc? If the surface has "glazed-over" they will not be operative.
    I am brackish.  They are not zinc anodes that you replace every year.  From my research, once Aero pointed me in right direction, these are additional anodes for additional protection. Now I wonder if they were added or came with boat.  PO kept boat on lift so why would he add them?  Maybe it's standard with my mercathode system as a whole.
    Patrick
    06 Rinker 270
    So brackish could be aluminum if they are stand alone. If they are a wired electrical cathode system there will be some wires inside going through the transom wall. If they are not a wired cathode electrical protection system and are stand alone anodes they must be replaced at some interval. I am in fresh water but the boat is kept at and visits marinas where stray shore power currents in the water are a given. Therefore, I use magnesium anodes and replace them every year as they show enough depletion that I couldn't get two years out of them and hauling-out to replace anodes half way through a second summer season would make no economic sense. I have seen anodes that looked new but were the wrong anodes for the water they were being used in and they had "glazed-over" my terminology and looked new. they were useless at that point. I agree that yours could be an add-on electrical cathode protection system but it would have wiring and would have to have continuity to be effective.
    Thank you guys, I will check this weekend if they are wired.  Can I check for continuity using my multimeter?  I hope they are not painted, I don't recall.
    @Alswagg, do you know if these come standard on Rinkers of my year or is this something someone added?
    Patrick
    06 Rinker 270
