Is it my T-Stat?
Glassguy54
Member Posts: 588 ✭✭✭
Had the boat out this weekend and the temp gauge was not reaching normal with in the expected time frame. Running at 3500-3800 RPM, the needle barely came off its perch. I took it up to 4800 RPM and ran for approx 20 min. and reached normal temp. After slowing back to 3500-3800, temp fell to below normal again. Does this seem like its a thermostat? What is the procedure for R&R? Remove all hoses from housing, undo bolts, lift T-Stat out, replace with new, then what? Do I need to add water to system for initial prime? Is raw water cooled BIII, 350 MAG MPI.
I didn't have to reprime. The raw water pump pushed the water through immediately.
