Hydraulic tilt/trim line leaking
I have a 2004 Rinker 312FV with twin 4 Volvo 5.0 OSI-F stern drive engines. The Port side hydraulic trim line is leaking. I had the marina mechanic look at it, (unfortunately, I do not fully trust his opinion, I have been burned in the past by them.) He stated that it was the low pressure line leaking. He said this line runs inside the boat. Which doesn't make sense, since the line is leaking outside the boat, as I can see an oil sheen in the water from the leak. He also said that in order to change the line, he has to remove the engine from the boat. Again, I cant believe that just to replace a hydraulic line that the whole engine has to come out of the boat. This doesn't seem right to me. Does anyone have experience on replacing the hydraulic trim line?
No, I didn't resolve the problem yet. I ran the boat without using the trim, ate up some gas, because it wasn't running efficiently. But, I figured, I would wait until October, when I pull the boat out for the season and have a look myself or get a second opinion from a Volvo authorized mechanic . I have a service manual and it doesn't mention anything about having to remove the engines to replace the lines. If anything, I would have to pull the drives off to get to the outside line. but not the engine. So, I wil see in October
Thank you.
I didn't think the engine would have to be removed. that would be very poor design on Volvo's part. But, you never know.. The block behind the outdrive, would make more se4nse, since the oil is leaking into the water outside the boat and not into the bilge. So the leak would have to be a connection on the outside, not the inside like the marina mechanic said.
