Oil Capacity for 1992 Rinker 202 4.3 Mercury GM
Mercury has the oil capacity for this 1992 4.3 6 cylinder motor mercury GM motor at 4.5 quarts. So I change the filter and in pore in 4.5 quarts then run the motor, shut it off and check the dip stick.
This amount of oil is 1" over the full mark on the dip stick. It would seem that this particular Merc motor would not take 4 or less quarts oil which to me seems like too little oil. The dip stick is marked 41092-1 which seems to be the correct stick. Maybe Rinker changed the oil pan on that model for the motor to fit the boat. Does anyone know what the correct oil amount is for this year and type of motor? Any one have any info as to why this might be.
Also I assumed you replaced the oil filter and lines were empty?
@Mark B has two good points. The first does happen too many times -incorrect aftermarket dipstick. I would assume that you replaced your oil filter BUT if you didn't and the filter had a check valve to retain some oil that would likely raise the level on the dip stick - too high. When I check my oil I have always checked it with the boat in the water (I have had trailered boats and boats on boat lifts) with the normal amount of gear and gas I usually use. I have never added the specified amount of oil in any engine the first time and I have had auto removal oil systems from the bottom of the pan. On engines where I could fill the oil filter then spin it on I would put about a half quart less, then heat the engine to operating temperature to check the level. After that I'd top-off the oil as required. With my new remote "upside down" filters filling them with oil can get messy. For those I add about a quart/liter less then I top-up as required. That process has never let me down. For me it has always been a two step job.....:-)
Yes I did change the oil filter. Thanks for your comments!
