Fresh water smells
2005 Fiesta Vee - we put fresh water in the tank and it comes out of the faucets stinking something awful. Black flakes and water at first and then will look cleaner but still smell. We have cleaned the filter, flushed fresh water through several times but can't seem to get rid of the stench. Any suggestions?
Black flakes ... not good. Find the fresh water tank and hold a flashlight up to it. The tank is light-colored plastic, so you'll probably be able to see if there's any dark discoloration inside.
If not, it's probably in the water heater as @MarkB said. You can probably remove some of the hoses and flush it with fast-moving hose water to see if that helps, and then do bleach.
