Lower unit fluid
rasbury
Member Posts: 8,818 ✭✭✭✭✭
Howdy, there have been a lot of threads recently on lower unit issues, perhaps we should have a section just for that?
I have a bravo III, 2005 and around 200 hours on it. Recently had an issue with the prop shaft seal which was replaced as it had a little leakage going on.....I noticed in the service manual the way the line comes through from the reservoir there is what is called a dribble valve. when the lower unit is removed and before it is put back on, it states to fill the reservoir and then push in on that valve to get the fluid flowing to purge the air-then install the lower unit so you don't have air in the system. Well, my repair was more like a change of fluid as the lower unit was not removed. I do not have any visible leaks going on and expected to add some fluid as the system absorbed the gear oil. I have probably re filled the reservoir completely once as I have been keeping an eye on it and topping it off a little at a time. What is normal here, where else can it be leaking that I would not see it? I have a friend that has been a mechanic for many years, worked as a service manger at a loca boat place as well and he says something about the connection in the transom can be leaking and "filling the boot" which I do not get at all looking at the manual....at some point he said where ever the fluid was leaking in, it would fill and eventually spill out into the bliege which I have not seen yet.... what is up with this lower unit???
Definitely best bet is to watch it and make sure it doesn't change color, especially more milky (like chocolate milk). That would indicate water is getting in.
Mark
2019 MTX20 Extreme
