I have a 2004 262 Captiva BR
Yesterday I found a blown 5A in-line fuse in the brown wire off the battery terminal. All wires off the positive terminal are red except this one. My issue is I can't fine anything that doesn't work. Wondering what this is for?
Best Answer
    Check the bilge pump, they are usually the brown wire and it should be wired to the battery. The float switch should kick it on automatically and the switch at the helm is the manual way to get it to turn on.
  • socchipinti77socchipinti77 Member Posts: 3
    Thanks! I wish check that out! Steelers pulled it out last night, you probably can't wait for Big Ben to make it back!
