How do you remove the bucket seat in a Captiva 226?
Our bucket seat broke and we are trying to get it off to get it fixed. I 've loosened the bolt and tried to pull it off. It goes about 2" and just stops. How do you get it off? Any suggestions would be appreciated! Thank you!
  • Michael TMichael T Member Posts: 7,231 ✭✭✭✭✭
    Need info. Are you trying to just get the seat with the slide mechanism off or the entire seat with the post and flange that is screwed into the floor.?
  • janelandjeffjanelandjeff Member Posts: 10
    Just the seat with slide mechanism. The area where the slide is broken from the seat. Thought we would get it fixed. Also need to find out where we can buy the white material that is on it. Would you know that? Thank you.
    I never took a seat off my 2013 226XL but I thought there were four bolts that held the seat on? I replaced the white slide on a 192 Rinker and got the part from my dealer who said they were able to get them from Rinker. If you could read the part number from it sometimes www.greatlakesskipper.com carries the parts. You can contact Rinker at 1-574-522-5184 or 1-888-463-3739.
