Raw water hose for cooling
Black_Diamond
Member Posts: 5,439 ✭✭✭✭✭
The hose from the sea strainer to genset (5e) is showing signs of strain/cracking. Likely due to the tight radius bend from the strainer thru the stringer. I was thinking of upgrading the strainer or moving it as it is really hard to get at on my 342, mounted way too low in the bilge. In addition, I was wondering about replacing the rubber hose with a braided stainless steel around rubber hose like this:
http://www.hosecraftusa.com/uploadedImages/HOSECRAFT AG1.pdf
The female connection is a hose/gasket type but thinking this might be OK since it would be mounted on the high/generator side. Any thoughts?
@BD, here are the pictures of the Forespar 150 with 50 mesh. I will be ordering a 40 mesh for waters that have smaller debris - algae. As you can see it is very sturdy. I took one with a ruler for scale then remembered I had a replacement strainer for the original genny and dug it up for a comparison shot. If you are interested in Forespar they have a good website. As I mentioned Groco and Raritan make decent strainers but IMO there is too much plastic on their strainer bodies which makes them too flimsy, IMO. The Forespar is made of Marelon which is almost indestructible and they are made to high standards for Mastercraft. BTW I do not like the older Forespar strainers that look flat with a removable top. I think the model number is Forespar 906066. I heard that Mastercraft had trouble with these and switched to the Model 150 that I have and all's well. Good luck BD!
