Spare tire
 tniggel
                    Member Posts: 66 ✭✭
tniggel
                    Member Posts: 66 ✭✭
             So I got a blowout on my trailer on the way to storage this fall. I'm replacing all four trailer tires the question is I am replacing d load with e load, could I use the one old d load as a spare for emergencies.
I highly recommend the Maxxis M8008's. Run from Goodyear's. I've seen 3 different sets start splitting around the circumference of the tread. I have no real complaint about your Carlisle's except that maybe mine seemed to dry rot a little premature. But, nothing near as bad as the GY.
Tough call on the spare. Use the old one and chances are good you could replace 2 flats when that first one has an issue. Again, to me this goes back to how much and how far you tow. Once or twice a year for 20 miles, maybe risk it. I just got back from a 1500 mile towing trip. I bought a new spare when I got the tires.
It has to be assumed there was either a road hazard causing damage or just a defectively manufactured tire. Coincidental that there was a story on the national news last night about tire recalls and lack of owner registration of tires.
It's a good point about checking pressure. If you go E-rated, it could be load rated at either 60 or 80 psig, so check the tire for yourself.
