Spare tire
 So I got a blowout on my trailer on the way to storage this fall. I'm replacing all four trailer tires the question is I am replacing d load with e load, could I use the one old d load as a spare for emergencies.
    edited October 2015
    Yes but it is probably dry rotted like the blow out one.
  • mattiemattie Member Posts: 1,318 ✭✭✭✭
    edited October 2015
    How old was the tire? Date code on the side. Manufacturers say every 3-5 years for replacement. That's prob too frequent for reality though. Date code is 4 digits - week/year.
    Post edited by mattie on
  • NRathNRath Member Posts: 135 ✭✭
    edited October 2015
    My opinion is that if you do much trailering, I'd go with the E load.  There is a slight bump in price, but my experience is that the stiffer sidewalls will help trailer tracking (sway).  Additionally, the couple extra ply's would help prevent that blowout.
    I highly recommend the Maxxis M8008's.  Run from Goodyear's.  I've seen 3 different sets start splitting around the circumference of the tread.  I have no real complaint about your Carlisle's except that maybe mine seemed to dry rot a little premature. But, nothing near as bad as the GY.
    Tough call on the spare.  Use the old one and chances are good you could replace 2 flats when that first one has an issue.  Again, to me this goes back to how much and how far you tow.  Once or twice a year for 20 miles, maybe risk it.  I just got back from a 1500 mile towing trip.  I bought a new spare when I got the tires.
    Mattie, I believe its every 7 years
  • halifax212halifax212 Member Posts: 555 ✭✭✭
    Had an original '04 tire as a spare mounted on the trailer. Went out one morning and it looked identical to the photo above. A 5 year old tire blew enroute from Cincinnati to Maine. Based on this I am replacing after 5 years as I tow about 20 to 30 times a season.
    Was it uncovered all that time on the trailer?
  • rasburyrasbury Member Posts: 8,592 ✭✭✭✭✭
    Also, make darn sure when you get your new tires they are inflated properly! I recently replaced my tires and did like one a month and I bought from a place that sells both trailer and car/truck tires- I think they had their gauges set to 35 PSI which is good for most passenger/lt truck tires but not these 60 PSI tires- the result was a new tire was underinflated and when I went across a bump, the tire squished so much it split it. Did not realize the culprit until I checked the air in the rest of the new tires and they were all that way- underinflated is a real issue. I never thought to check since they were new and I ASSUMED they knew what they were doing....
    The tire that split above was at the proper pressure. @tniggel and I set them on his trailer and mine a few days before he made his trek to storage. The tire didn't look dry rotted at all. If it would have looked bad, we would not have taken a chance with them.
    I'd agree with you CG & tniggel, that tire looks pretty good from what we can see in the pic.  I'd have towed on it, too.  I've seen them looking much worse and still haul a load.
    It has to be assumed there was either a road hazard causing damage or just a defectively manufactured tire.  Coincidental that there was a story on the national news last night about tire recalls and lack of owner registration of tires.
    It's a good point about checking pressure.  If you go E-rated, it could be load rated at either 60 or 80 psig, so check the tire for yourself.
    Sure can't go by looks when the tread separates..
    Under inflated or overloaded the tire will overheat and separate like that. Something few people consider is alignment, yes you can align trailer axles. Off kilter and they scrub/overheat/fail too. Had this exact problem with a 2-horse trailer.
     Very good point BD a lot of people never look at alignment makes a big difference.
    I went thru a pile of tow dollies checking alignment. I measured front at 3 oclock and rear at 9 oclock. All of them except 1 was off by at least a half inch to an inch. I bought the straight one because I returned the first one after it wore the tires down after 400 miles.
