Engine wont reach operating Temp.
Boat is a Rinker 242 with a 350 Mercruiser Mag MPI. Its currently at the shop and they just called and said it is not getting to operating temperature. It has been running rich and lacking power significantly. Most noticeably it wont plane out unless i tab all the way down and shift weight (have my wife crawl) to the bow. I imagine its not getting warm and thus the computer is constantly causing it to run rich and lack on its power. Thermostat and gaskets are brand new. I have not checked the impeller. Water pump was replaced new last winter. Any ideas where to start?
Thanks!
Thanks!
Props appear good to the eye, only a few tiny nicks. No growth on the bottom. Ive checked for slippage by hand and they feel good. At WOT it is running about 4800RPM at 46MPH with tabs all the way up and trimming the outdrive up until the porpoise starts and then going back down a little.
There is nothing on the boat to adjust the weight as its completely empty right now because im going to store it for the winter. The only thing that is extra weight that didnt come on the boat is two extra batteries and a subwoofer.
It seems to run fine when it gets onto plane, however it does not want to get on plane. Its a fairly small boat for a 300HP 350mag MPI. It should plane without having to use the tabs when the boat is empty, However with just me and my wife and nothing else on board if i dont use the tabs it will just dig the rear into the water and push water all the way across the lake. We have gone completely through the fuel system and replaced fuel pump and every injector has either been replaced or professionaly cleaned and flow tested. it has new plugs, wires, rotor, cap as well. Flame arrestor is clean. Throttle plates are opening all the way.
There is a very very slow leak in the engine bay somewhere and after being in the water for 30 minutes or so about a half gallon to a gallon of water will come out of the drain plug so i dont think there is enough water to cause an issue.
Im at a lost as to what to do.
Have you recently changed the prop? If so what pitch did you go for? Could be you have a top with more top and and less bottom end to help you with planing.
Where are your batteries? That could make a big difference especially on a bow rider.
I wouldn't be to stressed though about needing to use the trim tabs to plane if my top end was 46 mph.
OK, so what I figure is with 4 batteries and maybe placed towards the stern, could have impacted performance (I'm still suprised, but adding a couple of more batteries in the very back does add weight). The props might have been able to do it before the extra batteries were put on, but maybe not now. Only way to really find out is to take the new batteries out temperarily and go for a spin.
I have a 260EC fitted with a 350 MAG MPI and B3 drive. My props are 21P. I plane pretty easy, but it definetly affects my top end which at 4800 RPM is probably around 38 mph.
The 12 HP rule is a loose prediction of what it would take to gain 1 mph from your existing baseline hp/mph. So, if someone had 220hp that would do 40 mph and wanted to get to 50 mph they'd need another 120hp.
I have had the 360 do 49 mph but did not have the drives trimmed-up for that. I'm pretty sure it will do 50 with normal loads and trimmed right. Of course, heat and humidity are a huge determinant of HP.
I always ask anyone who is discussing modifications they think they need to make to their (props, skeg, bottom, etc) based on their mph if it is gps verified because, imo, there are very few speedos that I have found accurate. Livorsi/Gaffrig was the best non-gps speedo I aver saw and now I think even they have gone to gps.
I have read read of people with a 270 and even larger running the same motor and they can plane with 10 people and a load using tabs. The way my boat is it took me shifting everyone to the front, full tabs and a lot of time to plane with me and 5 others this summer. With this load of people I was also only able to get to about 36mph top end.
Brandon,
I don't know if this applies to your planning issue but the Bravo 3 drive on my '04 232 with 350 Mag has an elongated hole where the trim/tilt cylinders attach to the drive. There is a plastic spacer that can go in front of or behind the cylinders attaching bolt. I encountered a trim problem after taking my boat to a marine company to have it winterized a year ago. They removed the drive to grease and check things as part of their process. When they replaced the drive they put the spacer, which is in the drive and can be removed, behind the attaching bolt. My boat struggled to get on plane this past spring when trimmed down all the way. I researched what could be wrong and found out about this spacer. I changed spacer location and it was the difference for me. I also learned that a lot other boats require the spacer behind the cylinder attachment bolt.
What really got me focused on this was after having my boat winterized the drive hit my extended swim platform when lifted all the way up, which it had never done before the service. Changed spacer location and the drive did not hit swim platform and boat planed like it did before service.
This is something easy to check. Merc B3 service manual discusses this with some warnings about stern lift. Like you, I had other engine performance related issues that made things more complicated to diagnose.
Rob
Thanks again so much and ill try to update everyone in the spring.
Mine were spaced to allow more negative trim.
I like more negative trim, as I find most cruisers ride bow (nose) up anyway so I need less adjustment of trim "up" than I will need "down" so I always place the shims where they will allow the most travel In (-ve trim) or "down" of the drive(s).
