Bravo III problem?
Marcdohc
Member Posts: 58 ✭✭
Looking for some advise, My 05 300 FV with twin 5.0's and Bravo III's was sitting at my dock early in the season at low tide. Thats pretty much in the mud, as we headed out at 5 mph I lost power on one engine. I put it in nuetral and it started right up, but when I put in gear it died instantly. Being somewhat mechanical I figured there must be a short within the shifter. After messing with that for a half hour I decided I wasn't getting anywhere and decided to just buzz around at low speed and have it looked at later. Two minutes later I heard a loud metal bang and heavy vibration and sure enough I lost the other engine. I put it in nuetral and sure enough started right up but when I put it in gear it died. Just like the other one. We anchored and figured out we have propped fouled ourselves, twice! It took about an hour to untangle the 1" 25' line that I picked up. We brought up the anchor and headed out and everything was great again. The boat worked as it should all season. Well I took her out of the water saturday and after inspecting the drives the starboard which was the second drive to get fouled has a ton of side to side play. Like something is definitely wrong. Does anybody know what will need to be replaced. And for everyone else, when you start right up but every time you put her in gear she dies, guess what it is?
I once grounded and (as I later found out) put a tiny crack in a gimbal ring. Never knew until a month later when the ring broke and my drive almost went to Davy Jones' locker.
Healthy drive: less than 1"
Worn but still probably safe to drive: 3"
Any more than that and it's a serious problem that should be fixed right away.
