HVAC Fan
redlightning
Member Posts: 284 ✭✭✭
i have an HVAC system with the Passport control system. My question has to do with the fan. When setting a temp with the heat or cooling, is there a way to have the fan stop at some point after reaching the desired temp. Cycling on and off as needed when cooling or heating. Now the fan seems to stay on regardless if the system is heating or cooling.
http://www.dometic.com/QBankFiles3/EPiServer/Dometic/US/Manuals/Marine-manuals/Air-Conditioning/Controls/2231-Marine-Air-Passport-Control-Operation-Manual_21429.pdf
I thought the way I read the manual indicated it should cycle off. I have not tried it with the heat yet, but after changing the setting a few weeks ago, it didn't seem to cycle off when the compressor would cycle off when cooling.
sorry wrong thread.
yep, programming. I went to check the heater today since it will be 25 tonight.
checked the program and I guess I didn't save the programming change when I changed it earlier in the season.
Thanks for all the feedback
