New Batteries won't fully charge
                    Been two weeks since I was at boat, noticed when I left before I was getting a slow blink which means they are at low charge.  Batteries are new from April 2015.  I have been on shore power the entire time.  Battery charger breaker is on.  I am at 120 AC volts.  What is the proper steps to take to find out if it's the batteries or the charger?
The meter rest at 0 DC AMPERS. Does it only read when something is pulling?
thank you
thank you
Patrick
06 Rinker 270
      06 Rinker 270
13 volts is on shore power. I'll see what it reads when I disconnect.
I shut off the breaker for the battery charger and turned back on, same thing.
06 Rinker 270
But do used one for battries (acid) the are available at any auto stores and follow the instructions. Do not take a measurement when the battery is just out of the charger or with the charger on you will get a false reading let the battery rest for a few hours before using it
When I turn on the blower I see the meter go up to 5. Guessing it shows only when the DC is at load. Is this correct?
@frenchship is this right?
How can batteries be bad after 6 months?
06 Rinker 270
full voltage charge on a battery that's lost some juice is 14.5vdc on lead acid, but as high as 15.5vdc on gels/glass...
here is where it gets tricky: smart chargers will sense the standing charge and adjust what it sends to it... a lead acid battery only needs 13vdc to maintain charge, 13.5vdc is most common, though- depending on how smart it is...
I don't think you have a problem, man.
If the charger is pushing out 5 amps when the blower is on then I'm pretty sure it is working.
What is your voltage without the shore power on?
When I disconnect batteries next Tuesday I will test them with hydrometer and check electrolytes level.
At beginning of season the charger showed full power(fast blink). What would cause it to not show that anymore if all is ok?
I disconnected from shore power and I was at 12.8. Opened and closed the engine hatch and ran the blower for 4 minutes. I am at 12.1-12.2.
Took two cranks(maybe because it dropped to below 40F last night?),started engine and ran now I am at 13.6 - 13.8 with engine on.
Turned off engine, not connected to shore power let sit for 50 minutes with only the fridge pulling and it dropped to 12.5. Immediately after I shut off engine it was 12.9 for 15-20 minutes.
06 Rinker 270
06 Rinker 270
