Bravo 3 Gear Lube Reservoir Leaking?
rmrstlmo
Member Posts: 238 ✭✭✭
It appears that my gear lube reservoir is leaking. I have gear lube on the side of engine and in the bilge. I put a real metal clamp on the hose and I'm still getting quite a bit of oil leaking out. The reservoir will drain after about an hour of running. Anyone else had this problem? Any thoughts on what else it could be? Thanks for you help.
It item 27 in the link below:
https://www.mercruiserparts.com/Show_Pictures3.asp?dnbr=809808 96&ivar=images/COMMON/18730.png&inbr=1943&bnbr=330&bdesc=OIL+RESERVOIR+COMPONENTS
Ray
2006 390
Previous 2000 340
your "on the side of the engine" comment is thought provoking... is it leaking from the hose? have you seen it leak/drip or do you just notice the level go down? It could be that the resevoir is cracked. which happens often..
one time when I took my reservoirs off to clean I remember having the barb assembly on the bottom come loose, but couldn't get it tight without reaching into the bottle with needle nose or something and holding the float assembly in place, then I was able to get the bottom tight.
basically the lube bottle connects to the hose and then runs to another connector at the transom. I don't think there are any connectors in between. I would try to wipe down all the oil and locate the leak. Good Luck.
I've wiped it clean a couple of times and when I check it there is quite a bit of oil on the back side of the resevoir, down the side of the engine, and running down to the bilge.
I'll do some more investigating this weekend. I never thought about it coming out the top. Is there any other way of knowing that the drive is over heating?
Ray
2006 390
Previous 2000 340
Ray
2006 390
Previous 2000 340
Where does it vent? Is the vent obstructed?
I agree with the above comments, fwiw, in that the lube shouldn't have ANY whitish appearance unless water has been introduced.. that isn't good.. it would be a straight up milkshake if there was a lot, though.. was there a chance the drive was overfilled? Is there a chance it was the wrong viscosity of lube creating over expansion (boiling)? And- how does the drive unit valve between the unit and the reservoir? If whatever valve mechanism isn't valving, it could perpetually overfill the drive, which means it has to vent somewhere..
Ray
2006 390
Previous 2000 340
Ray
2006 390
Previous 2000 340
Ray
2006 390
Previous 2000 340
