Large Cruiser Engine Access
I am wanting to move up to a 340 class or larger Rinker. I had a 260 in '92 and a 270 in '07. There really wasn't anything I could not access to repair or service (DIY kinda guy). I must say I was taken by surprise when I raised the hatch of the '01 340 I just sea trialed (mentioned in gel coat cracks I posted). Access to anything, in particular batteries, pumps, gen, etc, would be difficult at best. I could not even get to the bilge float switch to test it. How do those of you with big twin cruisers deal with it? Completely remove engine hatch? Rely on a shop? Use a skinny kid? I just did not anticipate such a tight space after having single engine set ups. Thanks. Paul
Paul, the early 340s have to be one the worst for engine access. If you want decent access, move to looking at the 342s. The 2003/4 is still a bit tight, but in 2005 they moved engines back and much easier. I wouldn't but a boat that wasn't easy access to work on things. The 2001/2002 310s were also great to access everything. The 400 is also great. 420, IMO is not as good, especially items in aft/mid cabin.
So, if can maybe spend a tad more, look at 342s. Or 310s.
As an aside -- the 342 with 350's will plane at much lower speeds than the 340. It'll stay on plane down to 18 or even 15 mph. That is a big deal in rough water.
My friend has a 2005 342 that he is selling himself (he moved up to a 4460 Regal). We will be using it in the Annapolis Parade of Lights this Saturday. Paul, you could drive it down from my area.
@pault216, I'm really tall and I have the biggest engines Rinker will put in a 360 - so that's the most crowded it will get. To access the bilge pump and "stuff" at the rear of the engines and the inside transom wall I just throw a blanket over the engine (to avoid cuts from ring clamp ends etc. and I can reach anything. My tech is much shorter and he gets around just fine. He whines about access to the generator LOL but he manages to get at it! Access to batteries, waste tank, fresh water tank, water heater, battery charger, trim pumps, gasoline and tank sensor senders, all engine and drive fills, etc. is super easy, so it has to be better in any Rinker cruiser with 377s or 350s.
