How important is a blower?
Yeah,
I've heard all the stories about someones engine blowing up due to fumes in the engine compartment. but it sounds to me... it's out of stupidity by not being careful and opening up the engine cover before starting the motor. A simple precaution right?
I bought my (212 Rinker, carbed 350 mag) used and for some reason the blower was removed...but the hose was till there.
What other advantages does a blower provide?
and no.. it's not a personal problem... get your mind out of the gutter! really, I'm being seriousness here
@Artist: Gasoline fumes are heavier than air, so they sink to the lowest point, so just opening the engine hatch does nothing except let you smell and look around. You should be EXTREMELY concerned about not having/using a blower. It is the only think to keep fresh air moving through the engine compartment before start up and below cruise speeds. The intakes to the blower should be ideally at the lowest point in the bilge area.
Do a google search..it's not 'stories' you'll read, and it's not the engine blowing up, the whole engine compartment explodes. Usually with very bad results for those in/on the boat.
http://www.boats.com/reeds/jsp/rn_ch_2_a.jsp See the ventilation section
http://www.uscgboating.org/regulations/boatbuilder_s_handbook/vent_partc.aspx
FYI: you would fail a boat safety inspection and at least here in the USA, the CG or marine sheriff would find your boat a 'towback' if they checked you on the water (ie: not suitable for operation). Plus a nice handy-dandy fine.
Do yourself, your crew and anyone around you a favor and buy a blower(s) and use it, they are ~$30.
From my old days as an amateur pilot, I have a check list for startup. The things that are on it are the things I have missed/forgot to do. Switching on the blower(s) is on the list. Since there are two in my case, I feel for air coming out of the exhaust ports and also give this air a sniff. If I did not do this, I would have missed the fact that they do fail. So far I have had one go bad on two occasions.
I have mentioned this other thing a couple of times before but I will do a repeat anyway.
The blower is also good for keeping humidity out of the engine space while at the dock or on the hook. I frequently keep mine running just for that purpose.
Tony
Salt Shaker 342
Kind of related.....I found that the blower suction hose that runs from the blower to the bottom of the bilge was almost collapsed due to the type of hose (dryer vent type) and the installation technique. When going over a step, that style of hose tends to flatten causing a HUGE restriction. I found a high temperature hose that acts like a "bendi-straw" in that it can hold its shape when curved. I was able to form an S-shape that went from the blower, over the step, under the engine and lays parallel to the bottom of the bilge. I replaced the blower discharge hose with a high-temperature urethane wire-reinforced hose. I get way more flow now.
Mark
PS. This spring the blower started making a **** of a noise. Turns out, it has so much suction it inhaled a cap-plug that must have been in the bottom of the bilge. It was covered in gel-coat so it must have been used during the manufacturing process.
2019 MTX20 Extreme
