The best of times, the worst of times
![[Deleted User]](https://w5.vanillicon.com/5b2d60796d1edeb67376e6769d8a5b52_100.png)
2015 started badly. The expense of a new outdrive for my 250FV, then a leaky fuel tank that really tested my commitment to boating and hit my wallet hard. By May the boat was fully sorted, and the summer was just great, no issues. Here in So. California. Fall provided summer like weather well into December. All the while she purred like a kitten and performed like a new boat. Right before Christmas I took her out in some chop and she handled it well no problems at all. I love my Rinker.
So the year in boating has been one of contrast, a mix of good and bad, like much of life itself.
Happy New Year to my fellow Rinker skippers! How was your year in retrospect?
Andy
Andy
I'm fighting an overheat issue on one engine. Pulling the outdrives in Jan to see if it is a blockage there, then a new water pump. Already a new thermostat (old one worked too) and new exhaust shutters and exhaust bellows off the manifold done too (shutters were good). Only so much it can be!
@BD, yes, you have ticked all of the boxes I can think of except for a water supply hose that has lost its integrity and is collapsing under draw from the sea pump.
No offense meant to someone of your capability, but you have checked the gauge to make sure the engine is actually overheating or is it obviously overheating via the "touch test"? We went through this with a friends boat. It was an melted exhaust flapper restricting out flow. On another boat it was inlet water supply collapsing. On my boats it has been faulty primary temperature sender and/or the secondary gauge.
Just last summer with my new 8.2s it was water pressure and BOTH senders were off. Very frustrating and expensive to chase these things. In my case it was really aggravating as the engine guardian was restricting power (for no reason) to my Port engine which then eliminated Axius. Really maddening! Thank goodness for warranty!
On a complete '"ay out there question" ...is there any way that you were anchored close to a beach or sand bar and ran your engines. I have seen several cases where water supply systems ingested sand and caused overheating until they were flushed - which was quite a process.
I had a great summer of boating, and spent a better-than-average number of hours on the boat. But despite my best intentions, I never made it out of the Potomac River. That hasn't happened in at least 15 years.
Then I winterized the boat at the usual time in mid-November, and missed out on six weeks of great boating weather. Now, I've already finished most of my spring commissioning work -- and it's still December. So, yeah -- unusual year.
Brian
Andy
As damming rivers is no longer an option due to environmental laws, there are plans afoot to store the water in underground aquifers east of the base. Ironically, there is also a controversial desalination plant just south of Oceanside in Carlsbad that just opened. It is the biggest desal plant in the Western Hemisphere, cost a billion bucks, and produces 50 million gallons of expensive fresh water per day.
Bottom line, we live in a desert. Floods and droughts are typical here, not unusual at all. This one has been severe, but certainly not unprecedented.
Andy
